Spreadsheet
The Spreadsheet editor is used to inspect geometry attributes.
../_images/editors_spreadsheet_interface.png
The Spreadsheet editor.
Main Region
The main view allows you to view the actual spreadsheet. Row indices and column names remain visible when scrolling down or to the side.
ملاحظة
Byte color attributes are displayed as scene linear floats. The actual byte values are displayed in a tooltip when hovering over the float values.
Data Set Region
With the Data Set region on the left you can choose which geometry component and geometry domain to view. For each attribute domain its size is displayed, for example the number of faces.
Mesh
Mesh component containing point, corner, face and edge data.
Vertex:
Display attributes that are stored per vertex.
Edge:
Display attributes that are stored per edge.
Face:
Display attributes that are stored per face.
Face Corner:
Display attributes that are stored per face corner.
Curve
Display curve data which are the attributes on splines and control points.
Control Point:
Display attributes that are stored per control point.
Spline:
Display attributes that are stored per spline.
Point Cloud
Point cloud component containing only point data.
Point:
Display attributes that are stored per point.
Volume Grids
Display OpenVDB volume grid data, each grid will be represented with the Grid Name, the Data Type, and the Class. The class can be either of: Fog Volume, Level Set, or Unknown.
Instances
Display which objects and collections are instanced and their transforms.
Status Bar
The status bar shows how many rows and columns there are and how many have been filtered out.
