Volume Info Node¶
Volume Info Node.
The Volume Info node provides information about Smoke Domains.
Inputs¶
This node has no inputs.
Properties¶
This node has no properties.
Outputs¶
- Color
- Smoke color.
- Density
- Smoke density.
- Flame
- Fire density.
- Temperature
- Temperature of the fire. Values in the range [0, 1] linearly maps to temperatures in the range [0, 1000] in Kelvin.
Example¶
Smoke density.
Computing the color of fire using the Blackbody node. Since the Blackbody node expects its input in Kelvin, the temperature output has to be remapped first.
