Web3D X3D/VRML2
Reference
Category
Import-Export
Menu
File ‣ Import/Export ‣ X3D Extensible 3D (.x3d/.wrl)
Usage
TODO.
Properties
Import
Transform
Forward / Up Axis
Since many applications use a different axis for ‚Up‘, these are axis conversions for Forward and Up axes – By mapping these to different axes you can convert rotations between applications default up and forward axes.
Blender uses Y forward, Z up (since the front view looks along the +Y direction). For example, its common for applications to use Y as the up axis, in that case -Z forward, Y up is needed.
Export
Include
Selection Only
TODO.
Hierarchy
TODO.
Named Decorations
TODO.
H3D Extensions
TODO.
Transform
Scale
TODO.
Forward / Up
Since many applications use a different axis for pointing upwards, these are axis conversion for these settings, Forward and up axes – By mapping these to different axes you can convert rotations between applications default up and forward axes.
Blender uses Y forward, Z up (since the front view looks along the +Y direction). For example, it is common for applications to use Y as the up axis, in that case -Z forward, Y up is needed.
Geometry
Apply Modifiers
TODO.
Triangulate
TODO.
Normals
TODO.
Compress
TODO.
