BioVision Motion Capture (BVH)¶
Referenz
- Category
Import-Export
- Menü
Usage¶
Zu tun
The documentation here is incomplete, you can help by contributing.
Eigenschaften¶
Import¶
- Target
Zu tun
Transform¶
- Scale
Factor to increase the physical size of the BVH.
- Rotation
Zu tun
- Forward / Up
Since many applications use a different axis for pointing upwards, these are axis conversion for these settings, Forward and up axes – By mapping these to different axes you can convert rotations between applications default up and forward axes.
Blender uses Y forward, Z up (since the front view looks along the +Y direction). For example, its common for applications to use Y as the up axis, in that case -Z forward, Y up is needed.
Animation¶
- Start Frame
The start frame, in Blender, to start playback of the BVH animation.
- Scale FPS
Scales the frame rate from the BVH file to the scene frame rate set in Blender, otherwise each BVH frame maps directly to a frame in Blender.
- Loop
Cycles the animation playback.
- Update Scene FPS
Set the scene’s frame rate to match the frame rate of the BVH file.
- Update Scene Duration
Extend the scene’s duration to match the BVH’s duration.
