Attribute Map Range¶
The Attribute Map node.¶
The Map Range node remaps an attribute’s value from a range to a target range.
Inputs¶
- Geometry
Standard geometry input
- Attribute
The input attribute whose value is to be remapped.
- Result
Name of the attribute where the computed result is stored. If an attribute with this name does not exist yet, a new attribute with the same data type as the Attribute is used. If it does exist, the values of the existing attribute are overridden.
- From Min
The lower bound of the range to remap from.
- From Max
The higher bound of the range to remap from.
- To Min
The lower bound of the target range.
- To Max
The higher bound of the target range.
- Steps
The number of values allowed between To Min and To Max when using Stepped Linear interpolation. A higher value will give a smoother interpolation while lower values will progressively quantize the input.
- Clamp
If enabled, the output is clamped to the target range.
Eigenschaften¶
- Attribute
The name of the attribute to map with the value.
- Data Type
This determines the data type of the result attribute. This also changes the Min and Max inputs to match the data type.
- Interpolation Type
The mathematical method used to transition between gaps in the numerical inputs.
- Linear
Linear interpolation between From Min and From Max values.
- Stepped Linear
Stepped linear interpolation between From Min and From Max values.
- Smooth Step
Smooth Hermite edge interpolation between From Min and From Max values.
- Smoother Step
Smoother Hermite edge interpolation between From Min and From Max values.
Outputs¶
- Geometry
Standard geometry output.
