Bounding Box¶
The Bounding Box node.¶
The Bounding Box node creates a cube with the minimum volume that encapsulates the geometry of the input. The node also can output the vector positions of the bounding dimensions.
Inputs¶
- Geometry
Standard geometry input.
Eigenschaften¶
This node has no properties.
Outputs¶
- Geometry
The resulting box or cube to encapsulate the input geometry.
- Min
The coordinates corresponding to the cubes -X, -Y, -Z position values, i.e. how far the box extends in each of the negative axes directions.
- Max
The coordinates corresponding to the cubes +X, +Y, +Z position values. i.e. how far the box extends in each of the positive axes directions.
