Camera Data Node
Camera Data Node.
The Camera Data node is used to get information about the position of the object relative to the camera. This could be used for example to change the shading of objects further away from the camera, or make custom fog effects.
Inputs
This node has no inputs.
Eigenschaften
This node has no properties.
Outputs
View Vector
A camera space vector from the camera to the shading point.
View Z Depth
The distance each pixel is away from the camera.
View Distance
Distance from the camera to the shading point.
