ANT Landscape
This add-on creates landscapes and planets using various noise types. A.N.T. stands for Another Noise Tool.
Activation
Open Blender and go to Preferences then the Add-ons tab.
Click Add Mesh then A.N.T. Landscape to enable the script.
Interface
![../../_images/addons_add-mesh_ant-landscape_ui.jpg](../../_images/addons_add-mesh_ant-landscape_ui.jpg)
Located in the
menu.Located in the
tab.Instructions
After creating your landscape mesh there are three main areas in the Adjust Last Operation panel to design your mesh.
Main Settings: Object and mesh related settings like size and subdivisions.
Noise Settings: Noise related settings that give shape to your terrain.
Displace Settings: Settings for terrain height and edge falloff.
Landscape Panel
- Landscape
Landscape will create the mesh and add several panels and tools to the Sidebar.
Landscape Tools
- Mesh Displace
Displace selected mesh vertices along normal or X, Y, Z direction.
- Weight from Slope
Generates a weighted vertex group slope map based on the Z normal value.
- Landscape Eroder
Apply various kinds of erosion to an A.N.T. Landscape grid, also available in the Weights menu in Weight Paint Mode.
Landscape Main
Here we can adjust the main settings and regenerate the mesh.
Smooth the mesh, Triangulate the mesh, Rename and add materials that you have in your blend-file.
Landscape Noise
Here we can adjust the noise settings and refresh only those settings.
There are many settings and noise types that allow you to customize your landscape.
Landscape Displace
Here we can adjust the displacement settings and refresh only those settings.
Adjust Height, Falloff and Strata in this section.
Usage
Referenz
- Category
Add Mesh
- Description
Another Noise Tool: Landscape, erosion and displace.
- Speicherort
- File
ant_landscape folder
- Author
Jimmy Hazevoet
- Maintainer
- License (Lizenz)
GPL
- Support Level
Community
- Note
This add-on is bundled with Blender.
