Track Position Node
Track Position Node.
The Track Position node is used to return information about a tracking marker to the Compositor.
Inputs
This node as no inputs.
Eigenschaften
Movie Clip
Used to select a Movie Clip data-block to use, for controls see Data-Block Menu.
Tracking Object
Camera object to get track information from.
Track Name
The name of the track to get track information from.
Position
Which marker position to use for output.
Absolute
Outputs an absolute position of a marker.
Relative Start
Outputs the positions of a marker relative to the first marker of a track.
Relative Frame
Outputs the positions of a marker relative to the markers of the given Frame.
Absolute Frame
Outputs the absolute positions of a marker at the given Frame.
Outputs
X/Y
The marker’s X and Y location.
Speed
The velocity of the marker, measured in pixels per frame. This could be used to fake effects like motion blur by connecting it to the Vector Blur Node.
