Data-Blocks
The base unit for any Blender project is the data-block. Examples of data-blocks include: meshes, objects, materials, textures, node trees, scenes, texts, brushes, and even Workspaces.
../_images/files_data-blocks_outliner-blender-file-view.png
Blender File view of the Outliner.
A data-block is a generic abstraction of very different kinds of data, which features a common set of basic features, properties and behaviors.
Some common characteristics:
  • They are the primary contents of the blend-file.
  • They can reference each other, for reuse and instancing. (Child/parent, object/object-data, materials/images, in modifiers or constraints too…)
  • Their names are unique within a blend-file, for a given type.
  • They can be added/removed/edited/duplicated.
  • They can be linked between files (only enabled for a limited set of data-blocks).
  • They can have their own animation data.
  • They can have Custom Properties.
User will typically interact with the higher level data types (objects, meshes, etc.). When doing more complex projects, managing data-blocks becomes more important, especially when inter-linking blend-files. The main editor for that is the Outliner.
Not all data in Blender is a data-block, bones, sequence strips or vertex groups e.g. are not, they belong to armature, scene and mesh types respectively.
Data-Block Types
../_images/files_data-blocks_id-types.png
Data-blocks types with their icon.
For reference, here is a table of data-blocks types stored in blend-files.
Link
Library Linking, supports being linked into other blend-files.
Pack
File Packing, supports file contents being packed into the blend-file (not applicable for most data-blocks which have no file reference).
Link
Pack
Action
Stores animation F-Curves.
Used as data-block animation data,
and the Nonlinear Animation editor.
Armature
Skeleton used to deform meshes.
Used as data of armature objects, and by the Armature Modifier.
Brush
Used by paint tools.
Camera
Used as data by camera objects.
Cache File
Used by Mesh Cache modifiers.
Curve
Used as data by curve, font & surface objects.
Font
References font files.
Used by curve object-data of text objects.
2D/3D sketch data used by Grease Pencil objects.
Used as overlay helper info, by the
3D Viewport, Image, Sequencer & Movie Clip editors.
Collection
Group and organize objects in scenes.
Used to instance objects, and in library linking.
Image files.
Used by shader nodes and textures.
Keys (Shape Keys)
Geometry shape storage, which can be animated.
Used by mesh, curve, and lattice objects.
Light
Used as object data by light objects.
Library
References to an external blend-file.
Access from the Outliner’s Blender File view.
Line Style
Used by the Freestyle renderer.
Lattice
Grid based lattice deformation.
Used as data of lattice objects, and by the Lattice Modifier.
Mask
2D animated mask curves.
Used by compositing nodes & sequencer strip.
Material
Set shading and texturing render properties.
Used by objects, meshes & curves.
Metaball
An isosurface in 3D space.
Used as data of metaball objects.
Mesh
Geometry made of vertices/edges/faces.
Used as data of mesh objects.
Movie Clip
Reference to an image sequence or video file.
Used in the Movie Clip editor.
Node Tree
Groups of re-usable nodes.
Used in the node editors.
Object
An entity in the scene with location,
scale, rotation.
Used by scenes & collections.
Paint Curve
Stores a paint or sculpt stroke.
Access from the paint tools.
Palette
Store color presets.
Particle
Particle settings.
Used by particle systems.
Light Probe
Help achieve complex real-time lighting in Eevee.
Scene
Primary store of all data displayed and animated.
Used as top-level storage for objects & animation.
Sounds
Reference to sound files.
Used as data of speaker objects.
Speaker
Sound sources for a 3D scene.
Used as data of speaker object.
Text
Text data.
Used by Python scripts and OSL shaders.
Texture
2D/3D textures.
Used by brushes and modifiers.
Window Manager
The overarching manager for all of Blender’s user interface.
Includes Workspaces, notification system, operators, and keymaps.
World
Define global render environment settings.
Workspace
UI layout.
Used by each window, which has its own workspace.
Life Time
Every data-block has its usage counted (reference count), when there is more than one, you can see the number of current users of a data-block to the right of its name in the interface. Blender follows the general rule that unused data is eventually removed.
Since it is common to add and remove a lot of data while working, this has the advantage of not having to manually manage every single data-block. This works by skipping zero user data-blocks when writing blend-files.
Protected
Since zero user data-blocks are not saved, there are times when you want to force the data to be kept irrespective of its users.
If you are building a blend-file to serve as a library of assets that you intend to link to and from other files, you will need to make sure that they do not accidentally get deleted from the library file.
To protect a data-block, use the button with the shield icon next to its name. The data-block will then never be silently deleted by Blender, but you can still manually remove it if needed.
Sharing
Data-blocks can be shared among other data-blocks.
Examples where sharing data is common:
  • Sharing textures among materials.
  • Sharing meshes between objects (instances).
  • Sharing animated actions between objects, for example to make all the lights dim together.
You can also share data-blocks between files, see linked libraries.
Making Single User
When a data-block is shared between several users, you can make a copy of it for a given user. To do so, click on the user count button to the right of its name. This will duplicate that data-block and assign the newly created copy to that usage only.
Bemerkung
Objects have a set of more advanced actions to become single-user, see their documentation.
Removing Data-Blocks
As covered in Life Time, data-blocks are typically removed when they are no longer used. They can also be manually unlinked or deleted.
Unlinking a data-block means that its user won’t use it anymore. This can be achieved by clicking on the „X“ icon next to a data-block’s name. If you unlink a data-block from all of its users, it will eventually be deleted by Blender as described above (unless it is a protected one).
Deleting a data-block directly erases it from the blend-file, automatically unlinking it from all of its users. This can be achieved by Shift-LMB on the „X“ icon next to its name.
Warnung
Deleting some data-blocks can lead to deletion of some of its users, which would become invalid without them. The main example is that object-data deletion (like mesh, curve, camera…) will also delete all objects using it.
Those two operations are also available in the context menu when RMB-clicking on a data-block in the Outliner.
Custom Properties
../_images/files_data-blocks_add.png
Custom Properties panel.
Custom properties are a way to store your own data in Blender’s data-blocks. It can be used for rigging (where bones and objects can have custom properties driving other properties), and Python scripts, where it’s common to define new settings not available in Blender. It is also possible to access custom properties from materials via the Attribute Node.
Only certain data supports custom properties:
To add a custom property, search for the Custom Properties panel, found at the bottom of most Properties or Sidebar region, and click New. Properties can be removed from the same location with the delete icon. Once properties are added they can be configured via the edit icon to work for a particular use case; see Editing Properties for more information.
Editing Properties
Benutzeroberfläche
../_images/files_data-blocks_edit.png
Custom Properties edit pop-up.
Custom properties can be edited using the panel available for data types that support it. Editing the properties allows you to configure things such as default values, ranges, and even add a custom tooltip.
The data type of the property; different data types have can only have specific data properties.
Float
A numeric value with decimals e.g. 3.141, 5.0, or 6.125.
Float Array
A collection of multiple float data types e.g. [3.141, 5.0, 6.125] . This data type can also be used for data that can be represented as a float array such as colors. These special float arrays can be set in the Subtype selector.
Integer
A numeric value without any decimals e.g. 1, 2, 3, or 4.
Integer Array
A collection of multiple integer data types e.g. [1, 2, 3, 4] .
String
A sequence of characters such as „Some Text“.
Python
Edit a Python data type directly, used for unsupported data types.
Bemerkung
Boolean values must be handled as integers and only work when using Min/Max values that are integers and that are no more than 1 apart.
At this point, the Boolean values will still look like integers but behave like a Boolean having one lower, off, value and a higher, on, value.
Array Length
The number of elements in the array. Note that if the array length is greater than 7 you cannot directly edit its elements, you must press Edit Value to edit the elements of the array.
Property Name
The text that is displayed to the left of the value. This name is also used to access the property via Python.
Default Value
This sets the default value of the property used by the Reset to Default Value operator.
Warnung
Default values are used as the basis of NLA blending, and a nonsensical default (e.g. 0 for a property used for scaling) on a property intended for being keyframed is likely to cause issues.
Min, Max
The minimum/maximum value the custom property can take.
Library Overridable
Allow the property to be overridden when the data-block is linked.
Soft Limits
Enables limits that the Property Value slider can be adjusted to without having to input the value numerically.
Soft Min, Max
The minimum/maximum value for the soft limit.
Step
A multiplier to control how much the data type is incremented at a time. The internal step size for floats is 0.01, so a Step value of 5 will increment at a rate of 0.05 and a Step value of 100 will increment by 1.0. For integers the internal step size is 1.
Precision
The number of digits after the decimal to display in the user interface for float data types.
Subtype
Specifies the type of data the property contains, which affects how it appears in the user interface. In order for this property to appear the Property Value must be a vector of floats. For either of the color subtypes to work the Property Value must be a vector with three or four values depending on the availability of an Alpha Channel.
Plane Data
Data values do not have any special behavior.
Linear Color
Color in linear color space.
Gamma-Corrected Color
Color in gamma corrected color space.
Euler Angles
Euler Rotation angles.
Quaternion Angles
Quaternion Rotation angles.
Allows you to write a custom Tooltip for your property.
Python Access
Custom properties can be accessed in a similar way to dictionaries, with the constraints that keys can only be strings, and values can only be strings, numbers, arrays of such, or nested properties.
See the API documentation for details.
