Math Vis Console
Sometimes when writing Python scripts you stumble on complicated matrix transformations, ray intersections, rotation conversions, mesh modifications, etc. where its useful to view lines, points and matrices in the viewport to better understand the problem.
Creating mesh data for this purpose isn’t difficult but is cumbersome. The purpose of this add-on is to make it as quick and easy as possible.
Activation
  • Open Blender and go to Preferences then the Add-ons tab.
  • Click 3D View then Math Vis (Console) to enable the script.
Instructions
Math Vis works by displaying Python Console defined mathutils typed variables in the 3D Viewport.
The following types are supported:
  • Point: Vector(...)
  • Line: [Vector(...), Vector(...), ...]
  • Transformation: Matrix(...)
  • Transformations (without translation): Quaternion(...)/ Euler(...)
Nutzung
../../_images/addons_3d-view_math-vis-console_example.jpg
Create a Python Console editor. In the Python Console define a mathutils variable:
hello_world = Vector((1, 2, 3))
You should now be able to see this point in the 3D Viewport!
Referenz
Kategorie:
3D Ansicht
Beschreibung:
Display console defined mathutils variables in the 3D Viewport.
Properties ‣ Scene ‣ Python Console Menu
Datei:
space_view3d_math_vis.py
Autor:
Campbell Barton
Maintainer:
Campbell Barton
Lizenz:
*GPL*
Support Level:
Offiziell
Beachte:
Dieses Add-on ist gebündelt mit Blender.
