Attributes
An attribute is a generic term to describe data stored per-element in a geometry data-block. For example, every vertex can have an associated number or vector. Attributes can be altered by connecting a value to the Group Output node, but also many nodes can change the values of specific attributes.
Bemerkung
Attribute data types and domains are converted implicitly where possible, just like node sockets.
Named Attributes
Named attributes are created and used in other areas of Blender like shaders, painting, and UV mapping. In the modifier panel, a named attribute can be used for input by clicking the icon to the right of the value button. The string input input allows you to search and choose existing attributes from the modifier’s input geometry.
../../_images/modeling_geometry-nodes_attribute-reference_search.png
Attribute Search.
The attribute search gives a bit of context about each attribute. To the left of the menu, the attribute domain is shown followed by the attribute name. To the right of the menu, the attribute data type is shown.
Anonymous Attributes
../../_images/modeling_geometry-nodes_attribute-reference_attribute-field.png
The Normal and Rotation outputs are examples of attribute fields, which refer to an attribute stored on a geometry.
An anonymous attribute is a set of generic data stored on a geometry that doesn’t have a name. Usually, attributes exposed in Blender’s interface all have names. However, in geometry nodes, attributes can be passed around with node sockets. In these cases, an Attribute Field output is created, which is used by nodes to find attribute data in an input geometry.
Anonymous attributes are still stored on the geometry like other attributes, and they are even automatically interpolated when the geometry changes with other nodes, except for a few cases. So generally, if the node link is still accessible, the attribute it references will be available too. However, anonymous attributes cannot be connected to a completely separate geometry that was created from a different source. To transfer attributes between separate geometries, the Sample Index Node or other similar nodes like the Sample Nearest Surface Node can be used.
Attribute Data Types
The type of an attribute is the kind of data stored at each element.
Boolean:
True or false value
Integer:
32-bit integer
8-Bit Integer:
Smaller integer with a range from -128 to 127
Float:
Floating-point value
Vector:
3D vector with floating-point values
2D Vector:
2D vector with floating-point values
Color:
RGBA color with 32-bit floating-point values
Byte Color:
RGBA color with 8-bit positive integer values
The above list is in the order of least to most „complex“ (An integer can contain more data than a boolean, so it is more complicated). When joining separate geometries together, the more complex data type is preferred when there are matching names. This is particularly important when joining geometry with named attributes with the Join Geometry Node
To store 2D Vectors (UV maps) and Byte Colors the Store Named Attribute Node must be used because there are no sockets for those types.
Attribute Domains
The domain of an attribute refers to what type of geometry element the attribute corresponds to. Knowing the domain of an attribute is important because it defines how it may be interpolated and used in nodes and shading. You can use the Spreadsheet Editor to determine the domains of attributes.
  • Point domain attributes are associated with single locations in space with a position:
    • Vertices of a mesh
    • Points of a point cloud
    • Curve control points
  • Edge domain attributes are associated with the edges of a mesh.
  • Face domain attributes are associated with the faces of a mesh.
  • Face Corner domain attributes are associated with the corners of the faces of the mesh. An example is a UV map attribute.
  • Spline domain attributes are associated with a group of connected curve control points.
  • Instance domain attributes exist on the Instances in a geometry. They can be used to store different values on copies of geometry data. Instance domain attributes are only supported in geometry nodes.
Attributes are automatically interpolated to other domains. For example, when the Position Node is connected to the selection input of the Set Material Node node, the values are interpolated from the Point domain to the Face domain. Normally, domain conversions use simple averages for values, but Boolean data type attributes have special rules for interpolation:
Boolean Domain Interpolation
From
To
Conversion
Point
Edge
An edge is selected if both of its vertices were selected.
Point
Face
A face is selected if all of its vertices were selected too.
Point
Corner
Each corner’s value is simply a copy of the value at its vertex.
Point
Spline
A spline is selected if all of its control points were selected.
Edge
Point
A vertex is selected if any connected edge was selected.
Edge
Face
A face is selected if all of its edges are selected
Edge
Corner
A corner is selected if its two adjacent edges were selected.
Face
Point
A vertex is selected if any of the connected faces were selected.
Face
Edge
An edge is selected if any connected face was selected.
Face
Corner
Each corner’s value is simply a copy of the value at its face.
Corner
Point
A vertex is selected if all connected face corners were selected and it is not a loose vertex.
Corner
Edge
An edge is selected if all corners on adjacent faces were selected.
Corner
Face
A face is selected if all of its corners were selected.
Spline
Point
Each point’s value is simply a copy of the corresponding value of the spline.
Built-In Attributes
Built-in attributes always exist, and cannot be removed. Their data type and domain cannot be changed.
Name
Domain
Hinweise
position
Vector
Point
Built-in attribute describing vertex or point locations, in the local space of a geometry. Any node that changes the location of points will adjust this attribute, like the Transform Geometry Node and the Set Position Node.
radius
Float
Point
A built-in attribute on point clouds used to set the size for the points in the viewport. Also built-in on curves, where it controls the size of each curve control point when converted to a mesh, or for other operations.
id
Integer
Point
Created by the Distribute Points on Faces to provide stability when the shape of the input mesh changes, and used on instances to create motion blur. Values are expected to be large, with no order. This attribute is used by nodes that generate randomness, like the Random Value Node. Unlike other built-in attributes, this attribute is not required, and can be removed.
material_index
Integer
Face
Used to specify the material slot for every face in a mesh.
crease
Float
Edge
Edge attribute used by the Subdivision Surface modifier. The values are limited to a range of 0 and 1.
sharp_face
Boolean
Face
Attribute determining if a face should have sharp (rather than smooth) shading enabled in the viewport or a render.
resolution
Integer
Spline
Determines the number of evaluated points between two control points of a spline. Only NURBS and Bézier splines have this attribute, for poly splines, the value is always one.
cyclic
Boolean
Spline
Determines whether the spline has a segment that connects its first and last control points.
handle_left
Vector
Point
Describes the location of the left handle of a curve control point, on the side of the curve’s start. Only exists when the curve contains a Bézier spline.
handle_right
Vector
Point
Describes the location of the right handle of a curve control point, on the side of the curve’s end. Only exists when the curve contains a Bézier spline.
Namens-Konvention
These attributes do not exist by default, but are used implicitly by certain parts of Blender. The data type of these attributes can be changed, just like any attribute besides the built-in attributes. However, the attributes might be expected by Blender to have a certain type.
Name
Hinweise
velocity
Vector
Used to create motion blur when rendering animations.
rest_position
Vector
Holds the position of points or vertices from before a geometry is deformed procedurally. Can be created automatically before Shape Keys and Modifiers are evaluated with the Add Rest Position option.
surface_uv_coordinate
2D Vector
Used to describe curve attachment locations on a mesh surface, typically used for hair use cases.
Custom Attributes
Vertex groups, UV maps and Color Attributes are available as attributes in geometry nodes. They are referred to by their name. Naming collisions (e.g. a vertex group and a UV map with the same name) should be avoided. If there is a naming collision, only one of the attributes is accessible in geometry nodes.
Attributes with any other name can also be created by nodes, when the name is used for the first time.
Note that geometry nodes does not always produce e.g. vertex groups if a node like Join Geometry is used. Similarly, if the data type of a vertex group attribute is changed from the initial „Float“ type, the attribute will no longer be a vertex group.
Attribute Conversion Operator
../../_images/modeling_geometry-nodes_attribute-reference_convert.png
This operator found in the Attributes panel of the property editor can change the domain or data type of an attribute.
Due to ongoing development in the area of attributes, many areas of Blender can not yet work with the generic (identified with a name, stored on any domain with any data type) attributes used by geometry nodes. That makes this operator an essential workaround in some cases where existing tools must be used with data generated from geometry nodes.
Modus
Generic:
Interpolate and convert the attribute between the domains and data types described on this page.
Vertex Group:
Create a Vertex Group from the attribute, which corresponds to a float attribute on the point domain.
Bemerkung
This operator only works on original object data, not including the results of modifiers, so any attributes added or changed by geometry nodes will not be affected. To change the type of an attribute generated procedurally, modifiers must be applied.
