Curve Tools
This add-on provides an extensive set of tools for the manipulating and editing of curves. Several CAD style curve tools are included.
Aktivierung
  • Öffne Blender und gehe zu den Preferences, und dort zum Add-ons Reiter.
  • Click Add Curve then Curve Tools to enable the script.
Interface
This add-on is split into sub panels with each panel having it’s own specific set of tools.
Curve Info
Referenz
Modus:
All Modes
Tool:
Sidebar ‣ Edit ‣ Curve Info
Curve
Print splines, segments and empty splines information to the Info header and Info editor.
Spline
Print splines information to the Info header and Info editor.
Segment
Print segments information to the Info header and Info editor.
Length
Calculate the length of the curve and show in the add-on’s panel.
Curve Edit
Referenz
Modus:
All Modes
Tool:
Sidebar ‣ Edit ‣ Curve Edit
Fillet/Chamfer
Round or chamfer Bézier point fillets.
Outline
Create an outline around a selected curve object.
Recursive Offset
Create an offset array.
Separate Offset/Selected
Separate the outline mesh from the original.
Subdivide
Subdivide selection or filleted corners.
Multi Subdivide
Subdivide with level of details.
Split at Vertex
Cuts the selected points creating openings.
Discretize Curve
Disconnect the selected points.
Array Splines
Create an array of the selected curves in Edit Mode.
Intersect
Referenz
Modus:
All Modes
Tool:
Sidebar ‣ Edit ‣ Intersect
2D Curve Boolean
Boolean selected curves on a 2D plane.
Intersect Curves
Create an intersection between flat curves on the same plane.
Surfaces
Referenz
Modus:
All Modes
Tool:
Sidebar ‣ Edit ‣ Surfaces
Birail
It creates a surface from a profile and two paths. The order in which you select the curves and its direction is important to make this function properly.
Convert Bézier to Surface
Convert the selected curve to a NURBS surface.
Convert Faces to Bézier
Select faces and convert them to Bézier curves.
Loft
Referenz
Modus:
All Modes
Tool:
Sidebar ‣ Edit ‣ Surfaces ‣ Loft
Loft
Loft a mesh object between two Bézier curves.
Auto Loft
Turn on to store the loft data if you move or edit the curves.
Update Auto Loft
Press this button to update the new loft mesh position after moving or editing parent curves.
Sanitize
Referenz
Modus:
All Modes
Tool:
Sidebar ‣ Edit ‣ Sanitize
Set Origin to Spline Start
Move the origin of the curve to the first point.
Reset Scale
Reset the objects scale to (1, 1, 1).
Cleanup:
Remove Doubles
Remove doubled points.
Short Splines
Remove selected splines based on a threshold.
Join Splines:
Join Neighboring Splines
Join selected splines based on a threshold.
Utilities
Referenz
Modus:
All Modes
Tool:
Sidebar ‣ Edit ‣ Utilities
Curve Resolution:
Show [ESC]
Display the resolution in the interface with a colored overlay.
Spline Order:
Show [ESC]
Display and arrange the sequence.
Path Finder
Referenz
Modus:
All Modes
Tool:
Sidebar ‣ Edit ‣ Utilities ‣ Path Finder
Tools for paths.
Referenz
Kategorie:
Add Curve
Beschreibung:
Adds functionality for Bézier/NURBS curve/surface modeling.
Sidebar ‣ Edit tab
Datei:
curve_tools folder
Authors:
MacKracken, cwolf3d, Alexander Meißner (Lichtso)
Contributors:
guy lateur, Alexander Meißner (Lichtso), Dealga McArdle (zeffii), Marvin K. Breuer (MKB)
Maintainer:
Vladimir Spivak (cwolf3d)
Lizenz:
*GPL*
Support Level:
Community
Beachte:
Dieses Add-on ist gebündelt mit Blender.
