Is Shade Smooth Node
The Is Shade Smooth node outputs true for each face of the mesh if that face is marked to render smooth shaded. Otherwise, if the face is marked to render as flat shaded, so the node outputs false.
Inputs
This node has no inputs.
Eigenschaften
This node has no properties.
Outputs
- Smooth
Boolean value that indicates whether the normals of each face corner on the final mesh are smoothed with normal of all adjacent faces or not.
