Attribute Remove¶
![../../../_images/modeling_geometry-nodes_attribute_attribute-remove_node.png](../../../_images/modeling_geometry-nodes_attribute_attribute-remove_node.png)
The Attribute Remove node.¶
The Attribute Remove node removes a number of given attributes from each element of the given Geometry.
Inputs¶
- Geometry
Standard geometry input.
- Attribute (Multi-Input)
The name of the attribute to remove. Multiple attribute can be removed at once by connecting multiple String Input nodes. Built-in attributes and attributes that don’t exist can’t be removed.
Properties¶
This node has no properties.
Output¶
- Geometry
Standard geometry output.
