Curves Info Node
Curves Info Node.
The Curves Info node gives access to Hair information.
Inputs
This node has no inputs.
Properti
This node has no properties.
Outputs
Is Strand
Outputs 1 when the shader is acting on a strand, otherwise 0.
Intercept
The point along the strand where the ray hits the strand (1 at the tip and 0 at the root).
Jarak
The total measurement from the root to the tip of the strand, interpreted as a grayscale value from 0 to infinity.
Thickness
The thickness of the strand at the point where the ray hits the strand.
Tangent Normal
Tangent normal of the strand.
Random
A random per-curve value in the range from 0 to 1. It can for example be used in combination with a color ramp, to randomize the curve's color.
