Instance Scale Node
Instance Scale node.
The Instance Scale outputs the size of top-level instances on each axis in the local space of the modifier object.
The Instances page contains more information about geometry instances.
Inputs
This node has no inputs.
Properti
This node has no properties.
Outputs
Scale
Vector that indicates the scale of each top-level instance.
