Set Instance Transform Node#
Set Instance Transform node.
The Set Instance Transform node Transforms geometry instances using a Transformation Matrix.
The Instances page contains more information about geometry instances.
Inputs#
Instances
Standard geometry input.
Selection (Seleksi)
Boolean field used to determine if an instance will be rotated.
Transform
The transformation matrix to translate, rotate, and scale individual instances.
Properti#
This node has no properties.
Outputs#
Instances
Standard geometry output.
