Vertex Weight Proximity Modifier¶
This modifier sets the weights of the given vertex group, based on the distance between the object (or its vertices), and another target object (or its geometry).
Avvertimento
This modifier does implicit clamping of weight values in the standard (0.0 to 1.0) range. All values below 0.0 will be set to 0.0, and all values above 1.0 will be set to 1.0.
Nota
You can view the modified weights in Weight Paint Mode. This also implies that you will have to disable the Vertex Weight Proximity modifier if you want to see the original weights of the vertex group you are editing.
Options¶
The Vertex Weight Proximity modifier panel.
- Vertex Group
- The vertex group to affect.
- Target Object
- The object from which to compute distances.
- Proximity mode
- Object Distance
- Use the distance between the modified mesh object and the target object as weight for all vertices in the affected vertex group.
- Geometry Distance
Use the distance between each vertex and the target object, or its geometry.
- Vertex
- This will set each vertex’s weight from its distance to the nearest vertex of the target object.
- Edge
- This will set each vertex’s weight from its distance to the nearest edge of the target object.
- Face
- This will set each vertex’s weight from its distance to the nearest face of the target object.
Nota
If you enable more than one of them, the shortest distance will be used. If the target object has no geometry (e.g. an empty or camera), it will use the location of the object itself.
- Lowest
- Distance mapping to 0.0 weight.
- Highest
- Distance mapping to 1.0 weight.
Suggerimento
Lowest can be set above Highest to reverse the mapping.
- Falloff Type
Type of mapping:
- Linear
- No mapping.
- Custom Curve
- Allows the user to manually define the mapping using a curve.
- Sharp, Smooth, Root and Sphere
- These are classical mapping functions, from spikiest to roundest.
- Random
- Uses a random value for each vertex.
- Median Step
- Creates binary weights (0.0 or 1.0), with 0.5 as cutting value.
Influence/Mask Options¶
Those settings are the same for the three Vertex Weight modifiers, see the Vertex Weight Edit modifier page.
Example¶
This example shows the usage of distance from a target object to dynamically control a Wave modifier with a modified vertex group:
The blend-file, TEST_1 scene.
