Spreadsheet¶
The Spreadsheet editor is used to inspect geometry attributes.
The Spreadsheet editor.¶
Intestazione¶
- Object Evaluation State
Display the data of an object at different states of its evaluation.
- Evaluated
Display data from object with all modifiers applied.
- Original
Display data from original object without any modifiers applied.
- Geometry Component Type
Part of the geometry to display data from.
- Mesh
Mesh component containing point, corner, face and edge data.
- Point Cloud
Point cloud component containing only point data.
- Instances
Display which objects and collections are instanced and their transforms.
- Attribute Domain
Attribute domain to display.
- Vertice
Display attributes that are stored per vertex.
- Bordo
Display attributes that are stored per edge.
- Faccia
Display attributes that are stored per face.
- Face Corner
Display attributes that are stored per face corner.
- Breadcrumbs
The breadcrumbs shows three key parts of the path the evaluated object takes before showing the information in the Main Region. In the order from left to right, the first item displayed is the Active object. The next two items are displayed when a geometry node’s Preview Toggle is enabled. The first of these next items is the name of the Geometry Nodes modifier, the last item shown is the name of the active node.
Clicking the arrow between items hides the name of the active modifier.
- Toggle Pin
Usually, the editor displays data from the active object. When an object is pinned, its data remains visible, even if another object becomes active.
- Selected Only
This option is only available if the object is in Edit Mode. When checked, only data for the selected mesh elements is shown.
Regione Principale¶
The main view allows you to view the actual spreadsheet. Row indices and column names remain visible when scrolling down or to the side.
Barra di stato¶
The status bar shows how many rows and columns there are and how many have been filtered out.
