Join Geometry¶
The Join Geometry node merges separately generated pieces of geometry into a single one. If the inputted pieces contain different types of geometry, the output will contain multiple types of geometry.
The Join Geometry node.¶
Nota
The node cannot handle the case when more than one geometry input has a volume component.
Ingressi¶
- Geometria
Pieces of geometry that will be joined. Multiple inputs are allowed. When the node is muted, only the first link will be passed through.
Proprietà¶
This node has no properties.
Output¶
- Geometria
Standard geometry output.
