Scale Instances Node
The Scale Instances node.
The Scale Instances node scales geometry instances in local or global space.
The Instances page contains more information about geometry instances.
Ingressi
- Geometria
Standard geometry input.
- Selezione
Boolean field used to determine if an instance will be scaled.
- Scala
The scale factor to apply to the instance’s transform on each axis.
- Centro
The position from which the instance origins are scaled. Each instance will move away from this location. When the Local Space input is enabled, this location is relative to the initial transform of each instance.
- Local Space
If enabled, the instances are scaled in local space. In other words, they are scaled in the directions the described by the initial transform of each instance. When the input is disabled, the Center and Scale inputs are specified in the local space of the modifier object.
Proprietà
This node has no properties.
Uscite
- Geometria
Standard geometry output.
