Introduzione al sistema di finestre
After starting Blender and closing the Splash Screen, the Blender window should look similar to the image below.
La finestra predefinita di Blender all’avvio.
L’interfaccia di Blender è divisa in tre parti principali:
The Topbar at the very top, consists of the main menu, which is used for saving, importing and exporting files, configuring settings, and rendering among other functions.
Areas in the middle, which is the main workspace
The Status Bar at the bottom, which displays shortcut suggestions and relevant statistics.
Layout schermo predefinito di Blender. Topbar (blu), Aree (verde) e Barra di stato (rossa).
Personalizzazione
Keyboard shortcuts
Blender makes heavy use of keyboard shortcuts to speed up work. These can be customized in the Keymap Editor.
Colori del tema
Blender allows for most of its interface colors to be changed to suit the needs of the user. If you find that the colors you see on screen do not match those in the Manual, it could be that your default theme has been altered. Creating a new theme or selecting/altering a pre-existing one can be done by opening the Preferences and clicking on the Themes tab.
Accessibility
Blender has several options for visibility customization, including resolution scale, and the ability to load custom fonts. These settings can be configured in the Interface Preferences.
