Field at Index Node
Field at Index Node.
The Field at Index node allows accessing data of other elements in the context geometry. It is similar to the Sample Index Node. The main difference is that this node does not require a geometry input, because the geometry from the field context is used.
This node is also similar to the Interpolate Domain Node node, except that the value to retrieve from the specified domain is specified by an index rather than an automatic domain interpolation.
Ingressi
Index
The index of the element in the selected domain to retrieve data from, i.e. «the fourth face», or «the first control point».
Valore
The field to retrieve data from.
Proprietà
Domain
The attribute domain used for for evaluation of the Value input. This is useful because it can be a different domain than the domain from the field context, i.e. to choose a vertex for each face.
Output
Valore
The value of the input field at the given index.
