Vertex Weight Mix Modifier
This modifier mixes a second vertex group (or a simple value) into the affected vertex group, using different operations.
Importante
This modifier does implicit clamping of weight values in the standard (0.0 to 1.0) range. All values below 0.0 will be set to 0.0, and all values above 1.0 will be set to 1.0.
Nota
You can view the modified weights in Weight Paint Mode. This also implies that you will have to disable the Vertex Weight Mix modifier if you want to see the original weights of the vertex group you are editing.
Opzioni
The Vertex Weight Mix modifier panel.
- Vertex Group A, B
A: The vertex group to affect.
B: The second vertex group to mix into the affected one. Leave it empty if you only want to mix in a simple value.
- Invert Weights A/B
Invert the influence of the vertex group.
- Default Weight A, B
A: The default weight to assign to all vertices not in the given vertex group.
B: The default weight to assign to all vertices not in the given second vertex group.
- Vertex Set
Choose which vertices will be affected.
- Tutto:
Affects all vertices, disregarding the vertex groups content.
- Vertex Group A:
Affects only vertices belonging to the affected vertex group.
- Vertex Group B:
Affects only vertices belonging to the second vertex group.
- Vertex Group A or B:
Affects only vertices belonging to at least one of the vertex groups.
- Vertex Group A and B:
Affects only vertices belonging to both vertex groups.
Importante
When using All vertices, Vertices from group B or Vertices from one group, vertices might be added to the affected vertex group.
- Mix Mode
How the vertex group weights are affected by the other vertex group’s weights.
- Sostituisci:
Replaces affected weights with the second group’s weights.
- Aggiungi:
Adds the values of Group B to Group A.
- Sottrai:
Subtracts the values of Group B from Group A.
- Multiply:
Multiplies the values of Group B with Group A.
- Divide:
Divides the values of Group A by Group B.
- Difference:
Subtracts the smaller of the two values from the larger.
- Average:
Adds the values together, then divides by 2.
- Minimum:
Uses the smallest weight value of VGroup A’s or VGroup B’s weights.
- Maximum:
Uses the largest weight value of VGroup A’s or VGroup B’s weights.
- Normalize Weights
Scale the weights in the vertex group to keep the relative weight but the lowest and highest values follow the full 0 - 1 range.
Influenza
Those settings are the same for the three Vertex Weight modifiers, see the Vertex Weight Edit modifier page.
Esempio
Here is and example of using a texture and the mapping curve to generate weights used by the Wave modifier.
Using intensity. |
Using Red. |
Using Saturation. |
A customized mapping curve. |
Custom Mapping disabled. |
Custom Mapping enabled. |
The blend-file, TEST_4 scene.
