리지드바디(Rigid Body)
Calculate Mass
Reference
- Editor:
3D Viewport
- Mode:
오브젝트 모드
- Menu:
Calculate mass values for rigid body objects based on their volume and density. The volume is calculated automatically, the density needs to be given based on the object you want to simulate.
- Material Preset
A list of preset density values for real-world materials, if a material is not given you can research the density and use the Custom preset to input the density manually.
- Density
When the Custom Material Preset is selected, this is the input density, in kg/m3, to use.
