Vertex Color Node
Vertex Color node.
The Vertex Color node provides vertex colors as well as their alpha value.
Inputs
This node has no inputs.
Properties
- Vertex Color
The target vertex color. The listed vertex colors are those of the mesh of the active object. If the active object has no mesh, a warning will be displayed. If the property is marked in red, it means the vertex color is not available in the mesh of the active object, but it may be available in other meshes of objects that share this material!
Outputs
- Color
Vertex color.
- Alpha
Alpha value.
