Subdivision Surface¶
Subdivision Surface Node.¶
The Subdivision Surface node deform the geometry using Catmull-Clark deformation.
Inputs¶
- Geometry
Standard geometry input.
- Level
To which degree the geometry will be deformed.
- Creases
Control how smooth edges should be with Pesos de influência nos vincos das arestas.
- Boundary Smooth
Controls if open boundaries and corners are smooth.
- Smooth UVs
Controls if subdivision smooth is applied to UVs.
Properties¶
This node has no properties.
Outputs¶
- Geometry
Standard geometry output.
