Domain Size Node
Domain Size node.
The Domain Size outputs the size of an attribute domain on the selected geometry type, for example, the number of edges in a mesh, or the number of points in a point cloud.
For more information about attribute domains, see the geometry attributes page.
Inputs
Geometria
Entrada padrão de geometria.
Properties
Component
Which geometry type to retrieve the domain sizes from.
Saídas
Point Count
The size of the Point domain on any supported geometry.
Edge Count
The size of the Edge domain on meshes.
Face Count
The size of the Face domain on meshes.
Face Corner Count
The size of the Face Corner domain on meshes.
Spline Count
The size of the Spline domain on curves.
Instance Count
The number of top-level instances in the geometry. Nested instances are not considered.
