Mesh to Points Node
![Mesh to Points node.](../../../_images/node-types_GeometryNodeMeshToPoints.webp)
The Mesh to Points node generates a point cloud from a mesh.
Inputs
- Mesh
Standard Mesh input.
- Seleção
The meshes used to generate a point cloud.
- Posição
Positions of generated points. By default, this input is the same as if the Position Node was connected.
- Raio
Radii of generated points.
Properties
- Mode
- Vértices
Points are generated for each vertex.
- Arestas
Points are generated for each edge, at the middle of each edge, by default.
- Faces
Points are generated for each face, at the average of all of each face’s vertices, by default.
- Laterais
Points are generated for each corner. The points are all placed at the location of each corners vertex, so they will overlap by default.
Saídas
- Pontos
Generated point cloud.
