Self Object Node
Self Object node.
The Self Object node outputs the object that contains the geometry nodes modifier currently being executed. This can be used to retrieve the original transforms.
Nota
The geometry cannot be retrieved from this object with the Object Info Node, since its final geometry is still being evaluated.
Inputs
Este nó não possui conectores de entrada.
Properties
Saídas
Self Object
The object currently being evaluated.
