Denoise Node¶
![../../../_images/compositing_node-types_CompositorNodeDenoise.png](../../../_images/compositing_node-types_CompositorNodeDenoise.png)
Denoise Node.¶
The Denoise node is used to denoise renders from Cycles and other ray tracing renderers. This helps to significantly reduce render time by rendering with fewer samples.
It is uses Open Image Denoise, which transforms noisy images into clean images with machine learning.
Inputs¶
- Image
Noise image input.
- Normal
Optional normal render pass to better preserve detail. For Cycles, it is recommended to use the Denoising Normal render pass, which is available when enabling the Denoising Data passes.
- Albedo
Optional albedo render pass to better preserve detail. For Cycles, it is recommended to use the Denoising Albedo render pass, which is available when enabling the Denoising Data passes.
Properties¶
- HDR
Preserve colors outside the 0 to 1 range.
Outputs¶
- Image
Denoised image output.
