Movie Clip Node
../../../_images/compositing_node-types_CompositorNodeMovieClip.png
Movie Clip node.
This node is a special node that uses some of the values taken from footage cameras and trackings and link them to the output. It is possible to load image sequences, but only Image and Alpha values will be available, because the other outputs will not have any values associated with them. When a tracked clip is chosen, Blender will fulfill the outputs using internal values taken from the tracking. So the controls for start and end frames will be defined in the Movie Clip editor.
Inputs
This node has no input sockets.
Properties
Movie Clip
Used to select the movie clip. For controls see Меню блока данных.
Outputs
The first two sockets are the minimum output.
Outputs the entire image in the specified color space.
Alpha
The alpha value taken from the movie or image.
Offset X
The X offset value from the footage camera or tracking.
Offset Y
The Y offset value from the footage camera or tracking.
Scale
The scale of the image taken from the footage camera or tracking.
Angle
The lens angle taken from the footage camera or tracking.
