Window System Introduction
After starting Blender and closing the Splash Screen, the Blender window should look similar to the image below.
Početno stanje po pokretanju Blendera.
Blender’s interface is separated into three main parts:
Topbar at the very top.
Areas in the middle.
Status Bar at the bottom.
Blender’s default Screen Layout. Topbar (blue), Areas (green) and Status Bar (red).
Prilagodljivost
Blender opširno koristi tastaturne komande za brži rad. Sve se mogu podesiti po ličnom nahođenju u Keymap Editor (izbornik prečica tastature).
Boje interfejsa
Blender allows for most of its interface colors to be changed to suit the needs of the user. If you find that the colors you see on screen do not match those in the Manual, it could be that your default theme has been altered. Creating a new theme or selecting/altering a pre-existing one can be done by opening the Preferences and clicking on the Themes tab.
