Nút Đoạn Phim
../../../_images/modeling_geometry-nodes_geometry_convex-hull_node.png
The Convex Hull node.
The Convex Hull node outputs a convex mesh that is enclosing all points in the input geometry.
Ghi chú
When the node is used on a geometry with instances, the algorithm will run once per instance, resulting in many convex hull meshes in the instance geometries. The Realize Instances node can be used to get a convex hull of an entire geometry.
Quan trọng
Volumes are not supported by this node, and attributes are not automatically transferred to the result.
Đầu Vào
Hình Dạng
Hàm Tiêu Chuẩn.
Tính Chất
Đầu Ra
Bao Lồi
Mesh that encloses all points in the input.
