Nút Màn Chắn Đôi Cạnh (Double Edge Mask Node)
Trình Tổng Hợp Duy CPU (CPU Compositor Only)
The Double Edge Mask node creates a gradient between two masks.
Đầu Vào (Inputs)
- Màn Chắn Nội (Inner Mask)
A mask representing the inside shape, which will be fully white.
- Màn Chắn Ngoại (Outer Mask)
A mask representing the outside shape, which will fade from black at its edges to white at the Inner Mask.
Tính Chất (Properties)
- Cạnh Trong (Inner Edge)
- Toàn Bộ (All):
All shapes in the Inner Mask contribute to the gradient, even ones that do not touch the Outer Mask shape.
- Duy Kề Cạnh (Adjacent Only):
Only shapes in the Inner Mask that overlap with the Outer Mask contribute to the gradient.
- Cạnh của Vùng Đệm (Buffer Edge)
- Giữ Nằm Trong (Keep In):
Parts of the Outer Mask that touch the edge of the image are treated as if they stop at the edge.
- Tràn Ra (Bleed Out):
Parts of the Outer Mask that touch the edge of the image are extended beyond the boundary of the image.
Đầu Ra (Outputs)
- Mask (Màn Chắn)
Standard mask output.
