Edge Split
../../../_images/modeling_modifiers_nodes_edge-split.png
The Edge Split Node.
Like the Edge Split Modifier, the Edge Split node splits and duplicates edges within a mesh, breaking 'links' between faces around those split edges.
Note
Splitting edges effectively breaks the mesh topology.
Inputs
Geometry
Standard geometry input.
Edge Angle
When enabled, edges will be split if the angle between its two adjacent faces is greater than the Split Angle.
Angle
On 0: all edges are split. On 180: no edges are split.
Sharp Edges
When enabled, edges will be split if they were marked as sharp.
Properties
This node has no properties.
Outputs
Geometry
Standard geometry output.
