Attribute Mix¶
Mix attributes to creates to create a new attribute.
輸入¶
- Geometry
Standard geometry input.
- A, B
The first and second input to the mix operation. This can be an attribute name or a value.
- Result
Name of the attribute where the computed result is stored. The output attribute type is Color by default. When the result attribute exists already, its type is not changed.
屬性¶
- Blend Type
Operation that is performed on the inputs.
- Factor A, B
Input type for the corresponding socket.
Output¶
- Geometry
Standard geometry output.
