Workspaces
Workspaces are essentially predefined window layouts. Blender’s flexibility with Areas lets you create customized workspaces for different tasks such as modeling, animating, and scripting. It is often useful to quickly switch between different workspaces within the same file.
../../_images/interface_window-system_workspaces_screen.png
Workspaces are located at the Topbar.
Controls
Tabs
Click on the tabs titles to switch between the workspaces. To cycle between workspaces use Ctrl-PageUp and Ctrl-PageDown. Double click to rename the workspace.
Add +
Click on the Add button to add a new workspace.
Context menu RMB
The context menu contains options to duplicate, delete and reorder workspaces.
Default Workspaces
Blender’s default startup shows the „Layout“ workspace in the main area. This workspace is a general workspace to preview your scene and objects and contains the following Editors:
  • 3D View on top left.
  • Outliner on top right.
  • Properties editor on bottom right.
  • Timeline on bottom left.
../../_images/interface_window-system_introduction_layout-workspace.png
Blender’s Layout Workspace with four editors.
3D View (yellow), Outliner (green), Properties editor (blue) and Timeline (red).
Blender also has several other workspaces added by default:
Modeling:For modification of geometry by modeling tools.
Sculpting:For modification of meshes by sculpting tools.
UV Editing:Mapping of image texture coordinates to 3D surfaces.
Texture Paint:Tools for coloring image textures in the 3D View.
Shading:Tools for specifying material properties for rendering.
Animation:Tools for making properties of objects dependent on time.
Rendering:For viewing and analyzing rendering results.
Compositing:Combining and post-processing of images and rendering information.
Scripting:Programming workspace for writing scripts.
Additional Workspaces
Blender as a couple additional Workspaces to choose from when adding a new Workspace:
2D Animation
2D Animation:General workspace to work with Grease Pencil.
2D Full Canvas:Similar to „2D Animation“ but contains a larger canvas.
VFX
Masking:Tools to create 2D masks for compositing.
Motion Tracking:
 Tools to motion track and stabilize footage.
Video Editing
Video Editing:Sequence together media into one video.
Save and Override
The workspaces are saved in the blend-file. When you open a file, enabling the Load UI in the File Browser indicates that Blender should use the file’s screen layouts and overriding the current layout. See Load UI.
A custom set of workspaces can be saved as a part of the Defaults.
