Attribute Math
Modify an attribute with a math operation.
../../../_images/modeling_modifiers_nodes_attribute-math.png
The Attribute Math Node.
Inputs
Geometry
Standard geometry input.
A, B
The first and second input to the math operation. This is either an attribute name or numeric value.
Result
Name of the attribute where the computed result it stored. A new attribute with that name is added if it does not exist yet. If it does exist, the values of the existing attribute are overridden.
Properties
Operation
The math function to perform.
Bemerkung
Attributes are converted implicitly to the float data type.
Type A, B
Attribute
The input is a text field that expects an attribute name.
Float
The input is a number field.
Output
Geometry
Standard geometry output.
