Workspaces¶
Workspaces are essentially predefined window layouts. Blender’s flexibility with Areas lets you create customized workspaces for different tasks such as modeling, animating, and scripting. It is often useful to quickly switch between different workspaces within the same file.
Workspaces are located at the Topbar.¶
Bedienelemente¶
- Tabs
Click on the tabs titles to switch between the workspaces. To cycle between workspaces use Ctrl-PageUp and Ctrl-PageDown. Double click to rename the workspace.
- Add (Hinzufügen)
+ Mit einem Klick auf den Add Button kann ein neuer Workspace hinzugefügt werden.
- Context menu RMB
Das context Menü beinhaltet Optionen zum Duplizieren, Löschen und neu Ordnen von Workspaces.
Default Workspaces¶
Blender’s default startup shows the „Layout“ workspace in the main area. This workspace is a general workspace to preview your scene and objects and contains the following Editors:
3D Viewport on top left.
Outliner on top right.
Properties on bottom right.
Timeline on bottom left.
Blender’s ‚Layout‘ Workspace with four editors.¶
3D Viewport (yellow), Outliner (green), Properties (blue) and Timeline (red).
Blender bietet standardmäßig auch einige andere Workspaces.
- Modeling
Für das bearbeiten von Geometrie mit Hilfe von Modelleierwerkzeugen.
- Sculpting
For das verändern von Meshes mit sculpting tools (verformenden Werkzeugen)
- UV Editing
Mapping of image texture coordinates to 3D surfaces.
- Texture Paint
Tools for coloring image textures in the 3D Viewport.
- Shading
Tools for specifying material properties for rendering.
- Animation
Tools for making properties of objects dependent on time.
- Rendering
Um Renderresultate an zu zeigen und zu analysieren.
- Compositing
Combining and post-processing of images and rendering information.
- Geometry Nodes
For procedural modeling using Geometry Nodes.
- Scripting
Programming workspace for writing scripts.
Zusätzliche Workspaces¶
Blender eine Vielzahl zusätzlicher Workspaces von denen man beim hinzufügen eines neuen Workspace wählen kann:
2D Animation
- 2D Animation
Standardworkspace um mit Grease Pencil zu arbeiten.
- 2D Full Canvas
Ähnlich wie „2D Animation“ aber mit größerer Zeichenfläche (canvas).
VFX
- Masking
Tools to create 2D masks for compositing.
- Motion Tracking (Bewegungsverfolgung)
Tools to motion track and stabilize footage.
Video Editing
- Video Editing
Sequence together media into one video.
Speichern und Überschreiben¶
The workspaces are saved in the blend-file. When you open a file, enabling the Load UI in the File Browser indicates that Blender should use the file’s screen layouts and overriding the current layout. See Load UI.
Eine eigene Zusammenstellung von Workspaces kann als Teil von :doc:`/getting_started/configuration/defaults`gespeichert werden.
