Curve Tools
This add-on provides an extensive set of tools for the manipulating and editing of curves. Several CAD style curve tools are included.
Activation
  • Open Blender and go to Preferences then the Add-ons tab.
  • Click Add Curve then Curve Tools to enable the script.
Interface
This add-on is split into sub panels with each panel having it’s own specific set of tools.
Curve Info
Referenz
Modus
All Modes
Tool
Sidebar ‣ Edit ‣ Curve Info
Curve
Print splines, segments and empty splines information to the Info header and Info editor.
Spline
Print splines information to the Info header and Info editor.
Segment
Print segments information to the Info header and Info editor.
Length
Calculate the length of the curve and show in the add-on’s panel.
Curve Edit
Referenz
Modus
All Modes
Tool
Sidebar ‣ Edit ‣ Curve Edit
Fillet/Chamfer
Round or chamfer Bézier point fillets.
Outline
Create an outline around a selected curve object.
Recursive Offset
Create an offsetted array.
Separate Offset/Selected
Separate the outline mesh from the original.
Subdivide
Subdivide selection or filleted corners.
Multi Subdivide
Subdivide with level of details.
Split at Vertex
Cuts the selected points creating openings.
Discretize Curve
Disconnect the selected points.
Array Splines
Create an array of the selected curves in Edit Mode.
Intersect
Referenz
Modus
All Modes
Tool
Sidebar ‣ Edit ‣ Intersect
2D Curve Boolean
Boolean selected curves on a 2D plane.
Intersect Curves
Create an intersection between flat curves on the same plane.
Surfaces
Referenz
Modus
All Modes
Tool
Sidebar ‣ Edit ‣ Surfaces
Birail
It creates a surface from a profile and two paths. The order in which you select the curves and its direction is important to make this function properly.
Convert Bézier to Surface
Convert the selected curve to a NURBS surface.
Convert Faces to Bézier
Select faces and convert them to Bézier curves.
Loft
Referenz
Modus
All Modes
Tool
Sidebar ‣ Edit ‣ Surfaces ‣ Loft
Loft
Loft a mesh object between two Bézier curves.
Auto Loft
Turn on to store the loft data if you move or edit the curves.
Update Auto Loft
Press this button to update the new loft mesh position after moving or editing parent curves.
Sanitize
Referenz
Modus
All Modes
Tool
Sidebar ‣ Edit ‣ Sanitize
Set Origin to Spline Start
Move the origin of the curve to the first point.
Reset Scale
Reset the objects scale to (1, 1, 1).
Cleanup:
Remove Doubles
Remove doubled points.
Short Splines
Remove selected splines based on a threshold.
Join Splines:
Join Neighboring Splines
Join selected splines based on a threshold.
Utilities
Referenz
Modus
All Modes
Tool
Sidebar ‣ Edit ‣ Utilities
Curve Resolution:
Show [ESC]
Display the resolution in the interface with a colored overlay.
Spline Order:
Show [ESC]
Display and arrange the sequence.
Path Finder
Referenz
Modus
All Modes
Tool
Sidebar ‣ Edit ‣ Utilities ‣ Path Finder
Tools for paths.
Referenz
Category
Add Curve
Adds functionality for Bézier/NURBS curve/surface modeling.
Speicherort
Sidebar ‣ Edit tab
File
curve_tools folder
Authors
MacKracken, cwolf3d, Alexander Meißner (Lichtso)
Contributors
guy lateur, Alexander Meißner (Lichtso), Dealga McArdle (zeffii), Marvin K. Breuer (MKB)
Maintainer
Vladimir Spivak (cwolf3d)
License (Lizenz)
GPL
Support Level
Community
Note
This add-on is bundled with Blender.
