Merge by Distance Node
The Merge by Distance node.
The Merge by Distance node merges selected mesh vertices or point cloud points within a given distance, merging surrounding geometry where necessary. This operation is similar to the Merge by Distance operator or the Weld Modifier.
Inputs
- Geometry
Standard geometry input.
- Selection
Boolean field that is true for parts of the geometry to be deleted. Unselected points will be completely unsed for the operation– they will not be merged into other points, and no points will merge into them either.
Tipp
When possible, using the selection input can be a simple way to speed up the node, since searching for nearby points is a relatively expensive operation that gets even more expensive when more points are involved.
- Distance
The distance to use for searching for nearby points.
Eigenschaften
This node has no properties.
Output
- Geometry
Standard geometry output.
Beispiele
Using the selection input to only merge some of the points in a point cloud.
