Stanford PLY
Referenz
- Category
Import-Export
- Menü
Warnung
Only one mesh can be exported at a time.
Eigenschaften
Import
The import does not have any properties.
Export
Include
- Selection Only
Todo.
Transform
- Forward / Up
Since many applications use a different axis for ‚Up‘, these are axis conversion for these settings, Forward and Up axes – By mapping these to different axes you can convert rotations between applications default up and forward axes.
Blender uses Y Forward, Z Up (since the front view looks along the +Y direction). For example, its common for applications to use Y as the up axis, in that case -Z Forward, Y Up is needed.
- Scale
TODO.
Geometry
- Apply Modifiers
Export objects using the evaluated mesh, meaning the resulting mesh after all Modifiers have been calculated.
- Normals
Todo.
- UVs
Todo.
- Vertex Colors
Todo.
Usage
Use the operator to import ASCII or binary PLY-files, you can select multiple files at once. For exporting, you can choose to enable or disable the modifiers during the export and you can choose which data you want to export (UV textures, Color Attributes, …).
