STL
Referenz
Category
Import-Export
Menü
File ‣ Import/Export ‣ Stl (.stl)
This format is useful if you intend to import/export the files for CAD software. It is also commonly used for loading into 3D printing software.
Warnung
Currently the script does not handle importing or exporting of normals and does not handle endianness, there is nothing in the STL specification about it.
Eigenschaften
Import
Transform
Scale
TODO.
Scene Unit
TODO.
Forward / Up Axis
Since many applications use a different axis for pointing upwards, these are axis conversion for these settings, Forward and up axes – By mapping these to different axes you can convert rotations between applications default up and forward axes.
Blender uses Y forward, Z up (since the front view looks along the +Y direction). For example, it is common for applications to use Y as the up axis, in that case -Z forward, Y up is needed.
Geometry
Facet Normals
TODO.
Export
ASCII
TODO.
Batch Mode
TODO.
Include
Selection Only
TODO.
Transform
Scale
TODO.
Scene Unit
TODO.
Forward / Up Axis
Since many applications use a different axis for ‚Up‘, these are axis conversion for these settings, Forward and Up axes – By mapping these to different axes you can convert rotations between applications default up and forward axes.
Blender uses Y Forward, Z Up (since the front view looks along the +Y direction). For example, it’s common for applications to use Y as the up axis, in that case -Z Forward, Y Up is needed.
Geometry
Apply Modifiers
Export objects using the evaluated mesh, meaning the resulting mesh after all Modifiers have been calculated.
Usage
Use the operator to import ASCII or binary STL-files, you can select multiple files at once. For exporting you can select multiple objects and they will be exported as a single STL-file. You can select between ASCII/binary file format (binary is more compact). You can also choose to enable or disable the modifiers during the export.
