Convex Hull Node
Convex Hull node.
The Convex Hull node outputs a convex mesh that is enclosing all points in the input geometry.
Bemerkung
When the node is used on a geometry with instances, the algorithm will run once per instance, resulting in many convex hull meshes in the instance geometries. The Realize Instances node can be used to get a convex hull of an entire geometry.
Wichtig
Volumes are not supported by this node, and attributes are not automatically transferred to the result.
Inputs
Geometry
Standard geometry inputs.
Eigenschaften
This node has not properties.
Outputs
Convex Hull
Mesh that encloses all points in the input.
