Delete Geometry Node
Delete Geometry node.
The Delete Geometry node removes the selected part of a geometry. It behaves similarly to the Delete tool in Edit Mode. The type of elements to be deleted can be specified with the domain and mode properties.
Inputs
Geometry
Standard geometry input.
Selection
Boolean field that is true for parts of the geometry to be deleted.
Eigenschaften
Domain
The domain on which the selection field is evaluated.
Point
The selection is on the points, control points, and vertices of the geometry.
Edge
The selection is on the edges of the mesh component. The other components are not modified.
Faces
The selection is on the faces of the mesh component. The other components are not modified.
Spline
The selection is on the splines in the curve component. For each spline, it will either be deleted entirely or not at all. The other components are not modified.
Instances
The selection is on the top-level instances, and the entire instance is removed if it is selected. If the input also contains realized geometry, that will be unaffected.
Modus
The type of elements to be affected. This only applies to the mesh component.
All
Vertices, edges, and faces in the selection will be deleted.
Only Edges & Faces
Vertices won’t be deleted, even if they are in the selection.
Only Faces
Only faces in the selection will be deleted.
Output
Geometry
Standard geometry output.
