UV Map Node
UV Map Node.
The UV Map node is used to retrieve specific UV maps. Unlike the Texture Coordinate Node which only provides the active UV map, this node can retrieve any UV map belonging to the object using the material.
Inputs
This node has no inputs.
Eigenschaften
From Instancer Cycles Only
See the From Instancer option of the Texture Coordinate Node.
UV Map
UV map to use.
Outputs
UV
UV mapping coordinates from the specified UV map.
