Chroma Key Node
Chroma Key Node.
The Chroma Key node determines if a pixel is a foreground or background (and thereby should be transparent) based on its chroma values.
Use this, for example, to composite images that have been shot in front of a green or blue screen.
Inputs
Standard color input.
Key Color
The background color usually selected using the color picker and the original image.
Eigenschaften
Acceptance
An angle on the color wheel that represents how tolerant the keying color is. Larger angles allow for larger variation in the keying color to be considered background pixels.
Cutoff
Controls the level that is considered the pure background. Higher cutoff levels mean more pixels will be 100% transparent if they are within the angle tolerance.
Falloff
Increase to make nearby pixels partially transparent producing a smoother blend along the edges.
Outputs
Image with its alpha channel adjusted for the keyed selection.
Matte
A black-and-white alpha mask of the key.
