Difference Key Node
Difference Key Node.
This node produces a matte that isolates foreground content by comparing it with a reference background image.
Inputs
Contains foreground content against the background that is to be removed.
The reference background image.
Eigenschaften
Tolerance
Where pixels match the reference background to within the specified threshold, the matte is made transparent.
Falloff
Increase to make nearby pixels partially transparent producing a smoother blend along the edges.
Outputs
Image with its alpha channel adjusted for the keyed selection.
Matte
A black-and-white alpha mask of the key.
